Has anyone been able to capacity test these modules?
An additional good info would be their manufacturing date. Discounting some 6 months to commissioning and assuming 1 cycle/day, one could infer a worst (?) case scenario regarding theses modules cycle count.
cant find mfg date, bit has 6/14 on plastic cover doesn't mean that's the mfg date of battery but the plastic that surrounds it. who knows late 2014 early 2015?
Am I correct in assuming that using these 24 volt batteries to power a 12volt load(rv is 12 volt) you would get double the amp hours. What would you use to reduce voltage from 24 to 12 volts. Is there a power loss in the reduction.
This would allow me to charge up the batteries at home and go camping for a week or two without having to recharge(i.e. solar) the batteries.
Thanks
Fred.
battery hookup and tech direct club have stated 85-90% capacity in tests
trust me I hope they test out well! I only purchased one and have no way to do a load test and I am one of those people who are new to lifepo4. that is why I am here, we have to go solar as it is economically unfeasible to bring in grid power to our property so either run a genset or go solar. If they test out good, my storage problem will be solved. I am thankful there are people here that are testing these who actually purchased them.WHERE are you seeing that?? Is that actual test or assumptions?? Did they actually do a load test?
both have said they have done load tests, tech direct club has developed a 130a plug in bms.
I've got two cycles on my play pack over 175ah and I did not push them on low or high voltage.
I agreeIn this sense I am talking about Passive being just watching the cells vs Active that does do balancing on the cells but with external power.
It would seem the tech direct guys see no problem setting these packs upright. I wouldn't. I like the little value add these guys do to get the max return and also usability out of the used packs.
