KevinC_63559
I recapped this in my personal journey thread, but wanted to repost under its own heading in hopes it will be useful to someone in the future.
As you may, or may not know, the Victron Lynx Distributor has an LED board that shows the status of each of the fuses, and a power light to show the board is up and running. If any fuse blows, its corresponding LED will light up red, and the power light will change from green to red. That much is pretty common knowledge.
What surprised me is that the LED board is not internally powered. Victron apparently presumed folks would either buy their Lynx Shunt or their Lynx BMS (both a bit pricey). Either of those will power the Lynx Distributor LED board. Alas, where that might have been common in the days of Lead-Acid batteries, today with modern LiFePO4 batteries, which have their own BMS, its rather redundant.
A quick search on Google will find YouTube videos on making a 12-24V to 5V inline adapter cable. Unfortunately, that doesn't work for 48V systems. It did, however, point out that the LED board just wants everyday 5V power. Everyday? Yeah... its what every USB adapter provides:
(early test with one of those ancient USB printer adapters with the end cut off)
No big surprise that the red and black wires provide +5V and ground.
What you need is a package of these and an appropriate crimping tool. I bought this one. Just make sure your buying RJ10, not RJ9, and that the crimping tool can handle RJ10.
After that, its minutes of work. Find just about any USB cable with a USB 1.0 or USB 2.0 connector. USB -> MicroUSB cables are very common, you probably have several lying around your residence. Clip off the MicroUSB (in this case) end, strip back about 1CM (a bit less than a 1/2 inch), isolate the red and black wires, cutting off the other two. Insert the red and black wires in the connect, with black to the far right, and red to the far left, if the locking pin on the connector is facing down. If unsure, look at any telephone plug with a clear connector on it and match the orientation of the black wire. Red goes to the other side. Ah, found an image on my phone, with the locking pin up (so black to the left):
The larger, wired connector is a typical RJ9 - you can see the black wire on the left and a yellow wire on the far right. The smaller RJ10 connector needed for the Lynx Distribution Bus connection is show above it.
Anyhow, simply crimp the RJ10 with the red and black wires on the appropriate sides and plug into either side of the Lynx Distributor Bus connection. If you use a modern USB cable, it should be easily routed through the prongs inside the Distributor and out:
Note, my Distributor is mounted upside down - something that is so common Victron provides a label to make it look up!
Note if you do not have the Distributor fully loaded, the unfused connections will display a red light. Just jumper the fuse block with a small piece of wire and the red light will go out. Obviously, don't run any load on those terminals!
Here is mine all buttoned up with the cover in place. You can see the black USB cable coming out of the provided slots in the upper right:
Finally, plug the other end into a USB port somewhere. I used a spare one on my Victron Cerbo GX - but anything should do.
