MDBAYBOATER
- Jan 26, 2022
- 2
It showed that it was at 100% charge. I'm not a battery expert by any stretch of the imagination but based on the videos I've seen LFPs should run at 12+ volts until about 10% remaining. After I turned the inverter off the battery monitor went back up to 12.6 volts and 81% charge. I have a portable power station that will run the same 350 watt heater for about 2 hours. Sorry I can't provide more info but I expected more out of the battery.What voltage did you charge it to? How did you conclude it was not LFP? 3.0 volts is a typical cut off voltage for LFP. NMC or other Lithium chemistries would charge higher and cut off sooner.
Portable Power Station OUKITEL CN505, 614Wh LiFePO4 Battery Backup,Solar Generator with 500W Pure Sine Wave 2xAC
