Are these cheapo "all in one" charge controllers any good? (more leaning into the 48v setup , also as its also mppt controller, not pwm)
Looking to play around with the idea of making a small diy setup.
main questions:
My main requirement is to be able to charge the batteries from grid too ( not just solar) and this kind of controllers seem quite good value for what they offer
do I need any certifications/qualifications to hook the AC into these? (AC out just going to an extension where i'd plug a frige/chest freezer + some other bits ocasionally)
Regarding grounding. do I have to put a earth rod for this on its own? or can/should hook it to the grid's "ground"? Same goes to the AC out, shouldnt that have a ground too ? surely i shouldnt just use the AC's L and N wires without some sort of grounding?
Do I need the landlord's permission to hook something like this? (solar panels apart, i can always put them on the ground/my own shed)
any general tips would be welcomed
5KVA Solar Inverter 48V 230V Pure Sine Wave Off-Grid Built-in 80A MPPT Charger | eBay
Pure sine wave inverter Built-in MPPT solar charge controller Configurable input voltage range for home applicances and personal computers via LCD setting Configurable AC/Solar Charger priority via LCD setting Configurable AC/Solar input priority via LCD setting Compatible to mains voltage or...
www.ebay.co.uk
3KVA/2400W Hybrid 24VDC 230VAC 50A PWM Pure Sine Wave Inverter UK | eBay
Find many great new & used options and get the best deals for 3KVA/2400W Hybrid 24VDC 230VAC 50A PWM Pure Sine Wave Inverter UK at the best online prices at eBay! Free delivery for many products.
www.ebay.co.uk
main questions:
