MrMike
Hello!
I have an RV with a 1000w solar system using an EG4 3k 48v inverter and 2 100ah 48v EG4 Lifepower batteries. The RV gets rented out, so I want a safe way to bypass the inverter so the RV only uses shore power (renters shouldn't be responsible for the health and welfare of this solar system). Here's how I'm thinking of wiring in a manual changover switch to either use the inverter or bypass it completely for renters.
My concern is when the system is on POS 2, Shore power only. The manual changeover switches on the market don't have enough terminals to cutoff the ground wires - so the inverter ground both for AC in and AC out would be bonded back to the shore power ground. Since the hot/neutral are definitely switched off, there shouldn't be a problem with ground loops - but I'd like anyone with more experience with these EG4 inverters to have a look and check my assumptions.
Thanks!
Thanks!
