RCinFLA
Solar Wizard
- Jun 21, 2020
- 3,544
Panels subjected to regular shading conditions are prone to have blown out open bypass diodes. Bypass diode can fail open or short but most often they get overheated and fail open. A shorted bypass diode is easy to detect as Voc of panel will be low due to the shorted bypass diode shorting across a series group of PV cells in the panel.
Especially when buying used panels, it is good idea to check bypass diodes before installing panels.
This is a method to check bypass diodes in a panel without intrusive testing requiring opening of junction box on panel.
