Yes! There would be concrete foundations to set walls on to further outsulate. Ah but the day of the pour the concrete truck called in sick.... Then the weather got too cold until March ;(Dont forget under it!
CorrectWhat kind of insulation you use, it looks like xps 2 inch
Eventually all those wall will be interior. There will be a insulated roof added also. This was quick & pretty cheep.regarding moister this is a clever choise, but why did you not use first a layer of pir sheets to get a higher rd value?
I've already got my forms in place. And those wall will be interior.For insulating the bottom/floor it is good enough to dig a small trench around your container and put insulation in it.
In the Netherlands the "Frost border" is 60 cm/22inch deep
To get strong concrete it has to be cured well. Only way it to keep it warm. Too hard, not worth the hassle.I am not aware about your weather conditions but if the concrete fabric can put 5 to 10% lye?NaOH (soap making stuff) you can poor concrete to about -7 celcius, provided that your "casting mold" is insulated a rd of 0.5 will be enough aka eps foam.
Thank you!I like your thinking and work, good job! keep on posting your progress.
Good luck, best Igor
Its outside. The only thing the mold is in is the caulking around the edge.You may need to pull out all the insulation
I actually had one. Need to get a hose for it & I'll run it when I have enough power. It drys by cooling... So I'll be running a heater & cooler at the same time....dehumidifier will do the trick....7 days below 50%
No where else to go. Place burned down Jan 31st & lived in a tent for several months before I got the container., BUT...sleep somewhere else, your berating out is what the feed on.
Do you have a price comparison to show how much cheaper it is? Insulation has always seemed cheap to me.I just got done outsulating my containers & it was less than $1000 for 2 20'ers. If you outsulate then you can use Superstrut & have no burnable materials in your container. WATCH
I consider it a cheaper method than insulating inside because of the other materials required to fix the insulation to the inside of the container & then make the walls usable. And the time required is a fraction of doin the inside. Also, putting the insulation on the outside makes the container thermal mass. I have all the room on the inside. My interior walls are finished. I hook my Superstrut right to the tie downs & build what ever I want. I am going extremely fire proof.Do you have a price comparison to show how much cheaper it is? Insulation has always seemed cheap to me.
Big timeoutside insulation no matter what forn is cheaper AND better then inside insulation....
Insulation can be very cheap or really expensive, it all depends on how much you want to save on your heating bill.Do you have a price comparison to show how much cheaper it is? Insulation has always seemed cheap to me.
ok thats a new one to try. MMmm winter is here.heated smoked wiskey
LOL! MMMMMM Now I am the hungry one.But why deep fry ice cream?
Wish you did not wrote that down....dessert for tonight(i am already drooling)
Total wrap the ice cream in hot pancakes, pour pre heated smoked wiskey over it, set on fire and serve.....
Did not make that one for a while.
I might have to try something like this. As the moisture comes back every day.To make your house more comfortable dry, why not use salt, plain old kitchen salt, it attracts moister.
Or:
Anhydrous calcium chloride
The hydrated salt can be dried for re-use but will dissolve in its own water of hydration if heated quickly and form a hard amalgamated solid when cooled.
It pretty cheap and can bought in buckets up to 25 kilo.
Put a thick layer on a plate and place several of them in your house....
Btw was there any progress on your build?
I'm tellin ya. Solar ppl have the goods!ok thats a new one to try. MMmm winter is here.
Thank you so much!Hi. I'm new here. I've just converted a shuttle bus into a ...''RV''... and moved into it a few weeks ago, even while converting and insulating it at the same time. Well, I just did my best in a very short time. So it's not that pretty inside, buy I insulated it almost completely. But after watching tons of videos on YT about converting small buses into RV, I found a video of a young couple living in a van in Canada explaining how they're dealing with the moisture problem during the winter. I learned that living in a bus (like a container) is totally different than living in a house. They installed 1 (or 2, I don't remember) 12 volt fans inside their van, and they ALSO always leave a window cracked open. So the moisture problem is taking cared of. That way, there's always an air exchange from inside with the outside air, so the moisture problem is taking cared of. So coming back to my situation, here I am, in my shuttle bus, the weather outside goes from -5 Celsius to up to -20 Celsius right now and I don't have any moisture problem. Unfortunatelly, the sun is very shy right now where I am, there were no sun for almost 2 weeks now... So I parked my shuttle bus in a camp ground with a 30 amps electric outlet, so I don't have the solar or stress problem. Before I learned that trick (a few weeks ago) I was closing the inside of my shuttle bus all tight from the outside with no air exchange between the inside with the outside air... Big problem, every morning, the water was glisening on the walls and dropping from the ceiling!!! So a container must be similar to a small (or a big) bus. So since your container is well insulated, leave some small gap(s) somewhere in your container so there can be air exchange with the oustside air. And use at least one 12 volt fan. I tried a small computer fan, but it was WAY too small, it was like not having a fan at all!!! Now I'm using a 6 inch fan, and it solved all my moisture problem. Only when I cook, then I really have to open (I mean crack) a few windows. I just thought that this could help with your moisture problem. Also, when I was looking what to buy for my solar system, I went with the 24 volt MPP Solar ''All in One'' that Will was talking about. But since there was almost no sun at all for the last 2 weeks here, that's why I decided to park my shuttle bus in a camp ground with the electricity included. In my case, all my solar pannels are still not installed right now, and also I unplugged my ''all in one'' system, and I recharge my battery bank with a small smart battery charger to maintain my batteries, but since I do have access to the grid power, I'm not really using my battery bank right now. But I'm here, still learning. There's just so much to learn. Anyway, I just hope this might help you.
