I picked up 8 90Ah LFP cells through AliExpress and got them wired up with an 8S LFP BMS to successfully make a 24V LFP Battery.
I got lucky - this was all before I discovered this site and the wealth of advice and expertise available here.
I’m now planning to build several 8S 280Ah LFP batteries using the 280Ah cells and am considering to purchase through Alibaba using the vendors recommended on this site rather than through AliExpress again.
I’ve seen Xuba and Haomi mentioned as two vendors from which members here have had good experience with but I am trying to understand the relationships before reaching out to them.
Am I correct that both Xuba and Haomi are ‘Trading Companies’ that do not manufacture these cells but rather purchase them in bulk from the manufacturer and then test, sort, and match them before selling in smaller quantities to individuals like us?
I understand that they may also do other light manufacturing such as tapping the aluminum screw posts, but I’m talking about manufacturing of the aluminum-sheathed LFP cell itself.
I’ve seen a few references to ‘EVE’ and datasheets for the ‘EVE LF280’ - is EVE the manufacturer of these 289Ah LFP cells distributed by Xuba and Haomi? If so, do we know whether Xuba and Haomi purchase direct from EVE or through a 3rd-party / broker?
If EVE is the manufaxturer of these 280Ah LFP cells, is there any way to purchase directly from them or do they limit their sales to large MOQ?
The 90Ah cells I purchased through AliExpress look identical to the LF105 pictured on EVE’s website but without any marking (save a QR code). I suspect they are EVE LF90 cells and am trying to understand whether there are multiple manufacturers making identical cells to these or merely multiple ‘trading companies’ reselling these EVE cells in small quantities.
It seems like purchasing through Xuba or Haomi is a safe way to navigate the mysteries of Alibaba and avoid the risk of ending up with B-Grade cells (using the advice from this board) but I’m still trying to understand the relationships back to the underlying manufacturer before deciding which way to go.
To the experts on this board who occasionally pop up with manufacturers datasheets or confident statements about which manufacturers are behind various cells pictured in a post:
1/ which is the recommended manufacturer to purchase the $70-80 280Ah LFP cells? EVE?
2/ what is the recommended channel to purchase small quantities (6-36 cells) of these cells to have confidence they will be Grade A and properly tested to spec, matched, and shipped?
I was willing to risk $360 on the 8 90Ah cells I purchased through AliExpress. They were very well packaged, within 1mV of each other, and while I have not yet performed a full discharge cycle test, I suspect they will prove to deliver close to the 90Ah promised.
Risking $400 just to learn is one thing, but before committing $1000s to new 14kWh and 28kWh batteries, I want to understand the relationships and the manufacturing flow...
