Inverter/charger:
https://www.amazon.com/dp/B09H4K8768/
The manual is here:
From Amazon reviews:
"It comes configured for lead acid battery, and the entire unit will remain unpowered if you hook up LiFePO batteries + the AC.. So, wire the AC only at first, then configure the battery settings. Then you can connect the battery."
I have LiFePO batteries, so I hooked up the unit to AC house power. Nothing shows up on the display. The manual says to check the battery or PV air switch (breaker I presume?). Not sure whether they are referring to the breakers in the unit itself, or... ? Press any key on the screen to exit from the screen setup mode. ...but nothing appears on the screen.
