Choosing a hybrid inverter — recommendations?
ASword
Vancouver, BC, Canada
I’m new here, and I see a few other threads with people looking for advice on their specific situations, I hope it’s not out of line for me to do the same. I don’t see a recent thread with a matching list of requirements and considerations.
I have a house with 200A service, 5.1kW grid-tie solar PV (with sell back) on roof, and an 8.5kW standby generator. Primary and secondary panels, with almost everything on the secondary. Automatic transfer switch that kicks on the generator when the grid goes out. The typical draw is less than 2kW, and have never overloaded the generator, but there are three loads that are on the main panel which I’d like to be able to selectively choose to run during an outage. They aren’t on the main panel because they would likely be too much for the generator, and the secondary panel is full!
So my current issues and wish list are:
  • Generator is much too noisy at night
  • Generator burns too much propane when lightly loaded (peak efficiency is at about 8kW)
  • Want instant switch to backup for a few reasons — the 10 seconds for the generator to start is really disruptive
  • Don’t get benefit of solar when grid is down
  • Would like to be able to run three of the heavier loads and have some sort of load shedding scheme
  • Provide generator support functionality (ie supplement generator output based on current load)
  • This would just leave two 240v breakers on the main panel which definitely don’t need to be backed up, so would ideally like to replace the big empty main panel with something more space effective
  • Want potential to add more PV, but can’t increase the amount of sell back I am currently allowed
  • Power company just introduced time of use billing option, so want to use a battery to leverage this
  • Strong surge and imbalance capability because a power reset event would be a serious marital issue
  • Control interface with which I can programmatically control the system, preferably Ethernet
Solutions I’ve been looking at (all with 15-30 kW LiFePo):
  1. Schneider 6.8kW XW pro — when I started looking into this over a year ago, this looked like the device to beat. Capacity a bit on the low side, but really strong surge & imbalance capacity. Looks like it is at or near end of life now though? And the firmware is less than ideal. But very robust hardware.
  2. Midnite Solar 10kW AIO — looks like a really strong contender. Has a couple of smart loads, but not enough and they wouldn’t work if inverter fails.
  3. EG4 GridBoss/Flexboss21 — has become my leading candidate since I became aware of it. Only system that directly solves the main panel issue and the smart loads. GridBoss looks like it’ll keep working even if inverter fails, plus it has a bypass that will power most from the grid although I think we lose generator if GB itself is put into bypass. Looks like some approvals still pending, but I’m at least six months away yet. This one looks like the simplest wiring job.
Any other systems that I’ve missed? There are quite a few products on the market which look close, but are ruled out when examining the details. Does the GridBoss have any competing products that fill the same niche? Seems pretty unique thus far.
Welcome to the forums!
I'm not current enough to know what manufacturers allow you to limit exports to a specific value.
But, what happens if you do export past the limit? The utility can curtail your power output through frequency shifting and that started going into effect in the U.S. back in 2015, so all grid-tied inverters support it now. Canada probably has something similar, so I'm not sure why they want you to regulate it.
GXMnow reports the export limit is pretty big in California, your Canadian utility might have similar high amounts and if so it might be something you never have to worry about. Might be worth checking your exports per month, and if you never come close it's something you safely can ignore. Even if you do, if it's a $5 fine and you do it once every July might not be worth it. ; -)
If throttling export at a limit isn't a standard feature yet, an inverter with an API would let you setup a program to monitor your export and turn export off/on. Even if you can't set it, it you're handy at programming you could set a watchdog program to monitor exports and alert you to manually change it if you coming close to the limit.
You're the second person I've seen asking about it, so any manufacturers that don't have it are probably working on it. Any manufacturer that already support zero-export would see this as a software upgrade.
...my current issues and wish list are...
Sounds like you want a battery sized to meet your wallet that reduces generator run time by having the generator only come on if the grid is down and battery is low?
I know you're looking for a new inverter recommendation, but what's you're existing grid-tied inverter? For example if you have Enphase microinverters and their 200 amp Enpower switch then it might be least expensive/trouble to buy their battery. I know Enphase can zero-out for net metering, but I'm not sure if they can set a monthly export limit.
If you have an EV (or been thinking about getting one) you might want to look into a bidirectional charger that uses the car as a battery for the house. Just did a post on that here that might get you started. They're new and expensive right now, prices are offset by incentive programs here (30%-50% off depending on local incentives, not sure what it'll be tomorrow when Trump takes office ; -), not sure if Canada has any similar programs.
Out of curiosity, when the grid goes out and the generator comes on, how do you prevent the solar PV from back-feeding the generator? A generator relay to disconnect the PV?
The utility is not going to frequency shift the entire grid to manage one inverter source. They can't frequency shift an individual customer.
Mike C.
Yes, sell back may well increase in the future, especially since our power utility seems to be starting to wake up to the reality that distributed generation is good for them. Nonetheless, I want to ensure whatever solution I go with can limit it. The ones I listed seem to be able to. I’ve got APC systems microinverters. They don’t have an appealing solution that meets my requirements.
Pretty sure the grid can’t frequency shift though.
I do have an EV, but drawing from its battery and reducing my mobility has never made sense to me.
The solar is currently on the main panel while the generator supplies the secondary panel via the transfer switch, so they are never electrically connected. An inverter based system like the three I listed would disconnect the AC coupled PV before connecting the generator to avoid back feeding the generator. It’s a bit unfortunate to not be able to run both at the same time, but I haven’t seen a system that can use them both while keeping them isolated. In practice though I expect the generator would run after the sun has passed out of view of the panels, if not completely gone down. The majority of outages occur when the days are relatively short, and running the generator in the evening to charge the batteries to make it through the night is entirely reasonable. 3-4 hours of runtime would put 15+ kWh into the battery, which should last until morning without difficulty as the house is quite efficient and well insulated. If I do add more PV, it would be dc coupled and able to supply power to the inverter while the generator is running… although this reminds me to add “generator support” functionality (ie supplement the generator output based on current load) to my list of requirements.
You missed my point Mike.
Why should the utility limit your export unless there is a grid over supply? In which case, frequency shifting everyone is appropriate.
Imagine the grid needs power on the last day of the month (e.g., Barstow went down), but gosh I'm over my quota and I can't supply it reducing everyone's costs so grid operators have to fire up a peaker plant and increase everyone's costs? That's silly and not in the best interest of the consumers. They know how much everyone has put in, if it's about fairness to exporters they can do that at the back end bill calculations to remove excess credits from over achievers during the curtailment period as needed.
For a lot of people it doesn't make sense.
For me, I typically drive less than 40 miles a day and I charge at home so the battery is generally always near full. You can set the maximum depth of discharge to ensure you always have enough power to drive somewhere. Same thing about using an EV to export power to the grid (VPP) for area like Massachusetts where utilities would rather buy power from consumers for less$ than pay big$ to fire up peaker plants, it's good money for battery owners (better than net-metering, people have reported earnings > $1000/yr), and good for other consumers (See connected solutions).
I think of it like this. A model S has a ~400 mile range and ~100 kWh battery. If a house consumes 20 kWh/d, than you could power the house for 3 days, and still drive 160 miles to a charging station (assuming all the local ones are down), to fill up, and drive back. Or, at 40 miles to/from work I'd get 3 days of driving and powering the house and hopefully they have the power up by then (if not, I can still hit a recharger on the way home). If your business is closed due to the storm impact, then the car's recharging via excess solar is stretching out the number of days it can provide power.
Plus I'm cheap. Buying a stand alone battery is expensive. Reusing the EV's battery? That's frugal! ; -)
Nice! A simple elegant solution.
Enphase's can, they make use of their high efficiency neutral-forming transformer built into the Enpower. But I suspect they still want either a very big generator, or an inverter based generator. I haven't tried my generator on it, I've got a crappy gas generator with shoddy power (But I can theoretically blackstart my system with it, so never upgraded. I'm ditching that noisy piece of junk as soon as Enphase's bidirectional chargers are out ; -).
I've heard they're good units, didn't I hear something about them having a storage solution... let's see... here it is: https://usa.apsystems.com/apstorage
No clue if it'll work with your setup. Good luck!
I have a few questions to Chilicon and will likely go with their micros, but below are the current most highly regarded hybrids, in no particular order. I see no advantage to string inverters. As to islanding with micros you can always add AC-coupled batteries.
- Fronius - Austria - 1 or 3 phase, no details.
https://www.fronius.com/en-us/usa/s...s-gen24-the-heart-of-your-photovoltaic-system
- SunGrow - China - best Chinese inverter of all. Monitoring is not as good as SolarWeb. Microinverter is not big enough, and only one phase. All requires iSolarCloud. Terrible product presentation.
https://en.sungrowpower.com/ProductsHome/0/all-products
- LuxPower
https://luxpowertek.com/hybrid-split-phase-lxp-lb-us-8-10k
https://luxpowertek.com/hybrid-split-phase-lxp-lb-us-12k
- EG4 12KPV -
has 240v split-phase, PV disconnect, resettable DC circuit breakers, wifi dongle (waterproof), at least 120DC to start... OFFGRID ONLY. Does not have load balancing, Xfer switch BUILT-IN (made by LuxPower)
https://eg4electronics.com/categories/inverters/eg4-flexboss-21/
https://eg4electronics.com/categories/inverters/eg4-12kpv-all-in-one-hybrid-inverter/
I was just watching a signature solar video about GridBoss/FlexBoss, and they seemed pretty clear that ac coupled and generator input can both happen simultaneously. They will flip the ac coupled relay off if the battery SoC gets too high and there is nowhere for the power to go. That’s pretty exciting. Can anyone confirm that?
I was just watching a signature solar video about GridBoss/FlexBoss, and they seemed pretty clear that ac coupled and generator input can both happen simultaneously. ... That’s pretty exciting.
That is cool, can you link the video?
After studying the GridBoss for a week or two, it really looks like a fantastic fit (literally, as in positioning and wiring). The frustrating part of that is that it’s the *only* one like it on the market (as far as I can tell), which locks me into EG4. If something went tragically wrong with EG4, I don’t see another product that would be able to directly replace it. And it only works with EG4 inverters, which is an unfortunate type of vendor lock in. I realize that the GB just hit the market, and it’s a new(ish) concept… but have any other vendors started making noises about doing something similar? Would be great if Midnite Solar, for example, had an equivalent.
The GB doesn't do anything that couldn't be replicated with multiple discrete boxes like transfer switches, smart relays, etc. The innovation is not in function but in integration into a convenient package.
Mike C.
Mike C.
Agreed, but space and convenience are significant factors. Still, that might be a reason to *not* go GB and instead use a more conventional wiring setup. I already have a setup that has a bunch of load control relays, and I could extend that approach.
What I would really like to do is have about 4-5 DPDT contactors which either connect their loads to the primary panel, or to a secondary panel. They would default to the primary but software could choose to switch them over if the power was out or perhaps some other reason to want it directly connected to the inverter. Other than that I guess it would just be replacing a couple of wiring runs with longer ones, and adding a bypass connection that skips the inverter and falls back to the generator transfer switch. I would probably need direct control over the generator as well so I could program it as I see fit.
I think I need to draw out my scheme.
The discussion threads on various people having issues with a few different inverters and/or the GridBoss makes it very clear to me that I want to ensure I have a very simple (i.e throw one switch) fallback solution that disconnects any new "inverter based solution", reverting to my current "grid + standby generator" solution. Possibly with the exception of restoring my existing AC coupled solar (losing a bit of PV isn't nearly as important as getting the grid and/or generator back).
Why are you not looking at the EG4 18Kpv as well? The appeal of the GB is apparently to save space and cost of external switches, but I don't really see much difference, in space or cost, between a GB + FB vs. an 18K + manual transfer switch.
If you're concerned about being able to completely isolate the GB and revert to a grid only configuration, an 18Kpv plus MTS would do that.
Because I have both a generator (with 5% THD) and AC coupled PV that I want to connect to the inverter. My read of the 18Kpv manual rules out my generator and the connection of both at once (even if they can’t operate simultaneously).
The more I read and plan a potential system, the more convinced I am that (for me) the killer feature of any inverter is it having a software control interface. Not yet another stupid app that you must use manually, but a programmatic interface over the network (preferably HTTP-based). This would have GET methods to expose the state of the inverter (e.g. what mode it is in, whether the grid and other inputs are up, battery SoC, etc), as well as POST methods to expose user controllable features (e.g. smart load relays, generator on/off, charging vs draining mode, grid/generator support on/off, etc). The basic configurability of an inverter is never going to satisfy my requirements, so exposing a robust interface will enable external systems to be programmed to control the inverter. Integration is key, and interfaces are the foundation of integration.
Fully documented and open interface? Good luck with that.
But many inverters have "Wifi dongles" connected to RS485, CANbus, etc, so there is an opportunity to intercept whatever control the inverter native app does and use that yourself. So it could be a bit of reverse engineering. That also doesn't assure the level of control you want is exposed even to the dongle.
My suggestion is to try and find an inverter which has the adjustments you want in its native app, and has great Solar Assistant support. That means the ability to control it remotely is there, and someone has figured it out mostly. You may need to snoop on those communications to figure out how it works.
There are some automations that SA can do which could help. For example, on my inverter, I have SA reducing battery charge current to 1 amp (basically zero, but zero is not an option) when SoC is 97% or higher. This keeps my battery from constantly being pushed to high voltage per cell, which should increase its life. SA handles this for me:
So maybe SA does enough, or maybe yo have to reverse engineer the protocol and do it yourself, but open and documented API out of the box seems rare, perhaps non existent for these types of devices.
Mike C.
Yeah, my expectations aren't that naive. :ROFLMAO:
Most of the devices seem to have the level of control via their apps that I want, so that tells me they're a fairly short step from having what I want. That doesn't mean they're close to doing it though, but if there's enough clamouring for it, they might listen. The problem with reverse engineering internal protocols arises when they make changes. And a secondary issue (which one manufacturer already voiced concern about) is that if they're just exposing a modbus config interface, there's a lot of stuff in there that is dangerous to touch. You could brick devices, or worse. Having the inverter "publish" an interface explicitly designed for "safe" interaction with their app and any other software, would be much preferable.
Solar Assistant is closed source though, right? So I can't dig into its source code and see what they're doing. That means more snooping, which can be error prone and magnifies the issue I mentioned above.
The battery charging settings like that are actually not what I'm personally interested in. In my mind, that falls into the category of stuff that are the inverter's business. Set the configuration once (or it comes set that way), and its job is to manage the battery. I'm interested in things like predicting how much PV I'm going to get tomorrow so that I know how much to draw from the grid tonight, telling my generator when to run and not run while the grid is down, controlling "smart loads" based on information outside the power system, etc. Logic like this doesn't belong in (and in many cases cannot be in) the inverter's onboard processor, but which wants to be controllable via automation systems. Rather than trying to control everything (and failing) and having people hack at their system (with potential dire consequences), these manufacturers should publish a simple control protocol. It doesn't need to be able to do everything... but if there's a button in their app, their ought to be an under-the-hood interface their app uses, and that could easily be exposed.
And these sorts of systems also must not rely on internet connectivity. The thought of exposing my power system to the internet gives me nightmares. A side effect of working in cybersecurity adjacent spaces, I guess.
I just noticed on the Schneider website that the 6.8kW XW Pro is now officially listed as being discontinued Dec 31, 2025. I had already pretty much ruled it out, but this makes it official.
