Choosing SPD
melbaylon
I've watched videos and read articles but I'm still clueless on how to definitively choose the proper SPD for my solar setup.
What I understand so far is that I need to connect/parallel the DC SPD to the PV cables going into my SCC. I'm not sure what SPD to use though. I mostly see 500Vdc and 1000Vdc online.
Those are fine, as long as your PV voltage will never get to 300v.
My VOC is 451v, and with temperature compensation 488v.
I see the max Voc of my SCC is 160V. Can you give me an explanation why the 500V and 1000V models will work just fine? I really want to understand it better. ?
The voltage rating is the voltage of when it kicks on and absorbs the energy. You don't want a rating that is at or lower than your output. Or, it will absorb all of your wanted production.
Just additional clarification: following that 500V and 1000V will work just fine for my 160Voc SCC, in my case, it is better to go for the 500V, right? I mean 'cause it's relatively closer to my SCC's max Voc. Similar logic with circuit breakers.
But if the SPD exceeds the SCC voltage alot, will it still protect the SCC ?
I mean up to 500v into a 160v SCC will surely fry it...
The goal is to be above expected normal voltage, plus a cushion for fluctuations. But, a lightning strike is going to exceed any of these arrestors. Keeping the arrestors voltage closer to your expected normal voltage, protects your system from other surges.
Like if a tree falls on power lines, and this voltage is somehow imposed into your system. Or if a roof leak manages to bridge a connection between the AC and DC systems, in your home.
For 160v system, it's safer to use a 300v arrestor.
I am confused. The image above from Midnight Solar shows the SPD on the PV side connected to two different positive PV busbars, probably because of two arrays? I though you were supposed to connect the SPD to both positive and negative. I probably misunderstand something.
Surge Protection Device negative goes directly to ground wire. The more direct to ground, the better, right?
Midnite Solar provides written and visual instructions.
