TommyinMiami
- Apr 2, 2022
- 35
I usually do things the best way I can BUT with this build, I'm doing it the dumdum way. Think it's ok?
I'm partially disabled and I need a way to help me with loading and unloading the boat from the trailer. I am installing an electric winch and an electric boat jack on my boat trailer. Also work flood lights, and a 110 outlet for tools etc.
The plan:
I already installed a dry box on the front of the trailer. It'll house a 100Ah LI battery to power everything.
The setup:
The battery will charge in 2 ways. I'll be getting 1 Amp from solar to keep her topped off and after I use powertools and works light etc. On days I use the boat the, trailer battery will be getting a charge from my towing vehicle. I have a 7 way hookup and can draw 30 amps from there, it has a 40 Amp fuse installed.
So this is where I chose not the best method. Instead of running a 20A DC-DC charger or an Xantrex Echo 15A charger, which is like a battery combiner relay type device, I suppose, Well anyway, the method I chose to do is run my tow vehicles 40A fused 12v aux wire to power a 1,000W inverter, then plug in a 10A or 20A battery charger into that, which will charge the trailer battery when it's in tow. I'll run a relay to the ignition to make sure it turns off when my tow vehicle turns off. I went this route because I have too many inverters and charges and no extra spare DC-DC chargers. I have a Renogy 40A DC-DC charger but that's too big.
So think this is ok, good to go? Or I should rethink this and do it the right way? It's obviously not the most efficient to do from DC-AC-DC but I don't think that matters much because my truck's alternator will gladly make an extra 20Amps.
The little details:
Inverter is Gowise Power (Same as Greiner)1000W cont. 2,000W surge
Battery Charger is waterproof NOCO on board charger
Tow vehicle From Alternator through 7 way tow harness to trailer battery is 10ga
Battery to Inverter wire - 6ga with a 100A fuse (MRBF terminal fuse)
Adding a 30A fuse between 20A charger and trailer battery.
The winch and electric jack will run to the battery on the trailer, all fused also.
All wiring is Ancor tinned copper marine wiring.
Questions:
The inverter has a ground plug on it... Do I wire that to the trailer chassis? and the negative at the inverter to the trailer battery?
Do I need to run a ground wire from the trailer battery neg terminal to the chassis of the trailer also?
The tow vehicle's harness has a ground wire that I've already attached to the trailer's wire that goes to the chassis.
Would you make any changes? Should I go bigger than 6ga 100A fuse on the wire from inverter to battery. I don't have any tools that are over 1000 watts and I don't think the inverter would even run anything over 1,000 but do you ever fuse and gauge to the surge watts? I fused at 1,200 watts I assume and 6ga can handle a little more I believe.
Thanks for any feedback.
The plan:
The setup:
The little details:
Questions:
