So I built a battery box with solar charge controller and various auxiliary ports for charging etc.
I have the negatives in a string that leads back to the battery (thru the load port of the scc) and a separate switch for turning on the voltmeter and powering the fuse panel (separate switches for each auxiliary port as well).
The situation is this: I power on the unit, all looking good but when I plug in a 75w inverter into one of the cigarette auxiliary ports (nothing plugged in) and flip the switch, the inverter light does not light up, the voltmeter cuts off and the auxiliary switch loses power. When I turn off the auxiliary port with the inverter attached and wait a few seconds, the switch light turns back on and the voltmeter powers back on. I checked all inline and fuse panel fuses and all are OK. I tried on the second cigarette port and it did exactly the same thing. When it all comes back online, the lighter ports work with other devices just fine...just NOT the inverter.
UPDATE: I bought a new inverter (same specs as the original) and tried again...same issue! I then realized that my renogy wanderer (10amp) is throwing a E04 code which means load short circuit. Any idea why a short circuit would happen here before anything is plugged into the inverter? After unplugging the inverter and restarting the controller all is fine again. So strange! I suppose I could bypass the controller or wire a cigarette port for the inverter directly to the battery to see what happens? Maybe rule out some things? Thoughts?
Any thoughts are appreciated! I'm a novice here! Just looking for some answers.
