Poor quality low cost breaker, replace with Bussmann/Blue sea,and it wouldn't complete the circuit
They are cheap for a reason. Good breakers cost money.For $72 I'll use a fuse. The one that failed cost under $12 shipped.
#FalseEconomy. So, tear it apart and tell us the results of your failure analysis!The one that failed cost under $12
Someone here did a test of them while connected to a bunch of Victron LFP batteries, it did end up ejecting a bunch of sparks and molten metal from the fuse so definitely not good for a gas boat. But still better than a cheap piece of crap that doesn't do anything or catches on fire just sitting there working.If you absolutely have to have something 12v and cheap. Used these on lead acid battery banks, although, I'm not sure I'd trust them with a large LiFePo4.
So it opened when you pressed the button, but wouldn't close again, and probably a purely mechanical problem? I guess that's a better failure mode than not tripping on overcurrent or not opening when you press the button.I drilled out the rivits and opened it up. It's basically a bimetallic plate and contact points like an old car. The contacts are not pitted and there is no sign of overheating. My best guess is the little plastic lever inside that opens the contact points was twisted out of place and partially broken which wouldn't allow it to move enough to release the contacts, although I may have damaged it during disassembly.
Dang. That's not good. So far nothing like that has occurred with pop's system, and we've popped a few of those mrbf fuses. Looking at the fuses, it was hard to even tell they were done.Someone here did a test of them while connected to a bunch of Victron LFP batteries, it did end up ejecting a bunch of sparks and molten metal from the fuse so definitely not good for a gas boat. But still better than a cheap piece of crap that doesn't do anything or catches on fire just sitting there working.
It's very unlikely your pops system had anywhere near the amps involved in that test.Dang. That's not good. So far nothing like that has occurred with pop's system, and we've popped a few of those mrbf fuses. Looking at the fuses, it was hard to even tell they were done.
Yeah, that's what I'm thinking. Ok, for a cheap alternative better than many other options for a small 12v lead-acid system, but IMO, it's a hard no with a larg'ish LiFePo4 bank. FWIW, all the fuses in the home system are class-T. For the first time ever, I'll be adding a dc mccb to the 48v inputs of the new nhx inverters. The breakers are more for on/off convenience than anything as those circuits are also covered by class-T fuses.It's very unlikely your pops system had anywhere near the amps involved in that test.
Knock off..knock off…knock off.. get the real deal …I shut off this breaker to do some work to the system and it wouldn't complete the circuit when turned back on. The breaker was on the positive cable for a 1000 Watt inverter. No smoke or heat detected and the breaker has never clicked off on its own. I put a fuse in its place for the time being.
Not sure what sizing you are going for but the 250A midnite breakers are on sale at altE store for $47+shipping, if you get two or more shipping isn't too bad:Yeah, that's what I'm thinking. Ok, for a cheap alternative better than many other options for a small 12v lead-acid system, but IMO, it's a hard no with a larg'ish LiFePo4 bank. FWIW, all the fuses in the home system are class-T. For the first time ever, I'll be adding a dc mccb to the 48v inputs of the new nhx inverters. The breakers are more for on/off convenience than anything as those circuits are also covered by class-T fuses.
Now you tell me,Not sure what sizing you are going for but the 250A midnite breakers are on sale at altE store for $47+shipping, if you get two or more shipping isn't too bad:
Midnite 250A 125V DC panel mount breakers for $47 at altE
I hesitate to share this one as I'm sure all 43 remaining units will be snapped up fairly quickly. Normally retail for around $90-100, altE was already the cheapest prior to this mega drop. I ordered what I could afford wish I could get them all lol. Rated for 50,000 AIC at 125V. Seems cheaper...diysolarforum.com
What enclosures are those? Ideally I could buy midnite DC disconnect boxes without the breakers for cheap but very rare to find them like that.Now you tell me,and I already have some enclosures that would work to front mount those breakers.
You might look here https://powerwerx.com/bussmann-cb285-100-circuit-breaker-surfaceFor $72 I'll use a fuse. The one that failed cost under $12 shipped.
That one looks identical to the one that failed. It would be interesting to have a look inside to see if there is any difference in construction. A steel pivot for the plastic lever (rather than plastic) would likely prevent a similar failure.You might look here https://powerwerx.com/bussmann-cb285-100-circuit-breaker-surface
The Chinese can clone the external appearance of something perfectly. Internals and actual functionality can differ wildly.That one looks identical to the one that failed. It would be interesting to have a look inside to see if there is any difference in construction. A steel pivot for the plastic lever (rather than plastic) would likely prevent a similar failure.
The one i posted is not a chinese knock off. They can also supply this one. I have no affiliation with any supplier. This breaker is designed to be used as a switch as well as a breaker. https://powerwerx.com/eaton-187f-waterproof-circuit-breaker-surface-mountThat one looks identical to the one that failed. It would be interesting to have a look inside to see if there is any difference in construction. A steel pivot for the plastic lever (rather than plastic) would likely prevent a similar failure.
If I had an extra $50 I'd buy one to disassemble but a fuse will work fine and be safe in my system.The one i posted is not a chinese knock off. They can also supply this one. I have no affiliation with any supplier. This breaker is designed to be used as a switch as well as a breaker. https://powerwerx.com/eaton-187f-waterproof-circuit-breaker-surface-mount
