I need to put in a couple 12v switches close to my batteries. My component compartment is starting to get crowded, it's getting untidy. I was looking at surface mount switches, something I can attach to the plywood on the wall. The selection is a bit limited. Maybe I'm not looking using the right terms. Most switches want to be installed in a panel, which I don't have. The switch does not need to be illuminated. SPST or SPDT would work. The switch needs to handle 20 amps. The load shouldn't ever be that high, closer to 12 amps. But I don't want to burn out the switch.
I have a DIN rail with plenty of room on it. I got to thinking of using a DC breaker as a switch on the DIN rail. Circuit breakers are relatively inexpensive and having the over current protection would be a plus. Good idea? Bad idea?
