Quattrohead
Emperor Of Solar
Lord help us all.
I am leaning toward the $100-ish range. It would be easier to get approved.edit - DC inrush - that means it has a high sample rate to catch the leading edge. For Ac it doesn't need the high sample rate - I found several on amazon that do it for around $100ish ... or you can get the Fluke-393 FC meter for $900ishOr the Fluke-375 FC for $350ish much less if you trust aliexpress
NOTE - I love Fluke meters and they are wonderful, but expensive and intended for folks that use them all the time on the job - Bulletproof as mentioned above and they cost it.
But - if you look at the specs on the Fluke and compare it to the $100 version you will see the cheaper meter is good enough for anything a DIY person is going to do. The extra accuracy is only good on a test bench when it matters. In the field it doesn't matter if you are .1 amps off when measuring 100amps.
The higher sample rate means you chops the incoming voltage waveform into more parts and then does averaging so you get a more accurate reading. This is really more important than the number of digits on the screen or the stated ± accuracy.
I am leaning toward the $100-ish range. It would be easier to get approved.![]()
DC Current | |||
Range | 999.9 A | ||
Resolution | 0.1 A | ||
Accuracy | 2 % RD + 5 digits[1] |
I bought several of those meters to make gifts to friends. All of the meters were wildly inaccurate when I tried to measure 12v. I tested the meters against my other accurate meters.my CEN-TECH that I got for free at Harbor Freight.
I use an Ames 1000A AC/DC clamp. Carefully read the instructions before use
CM1000A 1000A T-RMS AC/DC Clamp Meter
Amazing deals on this 1000A T-Rms Ac/Dc Clamp Meter at Harbor Freight. Quality tools & low prices.www.harborfreight.com
I bought several of those meters to make gifts to friends. All of the meters were wildly inaccurate when I tried to measure 12v. I tesetd the eters against my other accurate meters.
View attachment 215021I will put one on order today.
I am looking at this clamp meter. It shows that it can measure 40amps DC up to 400amps. Amazon clamp meter
They have a decent reputation. I use mine casually for my own projects and have only had it for about 6 months. Its a good affordable clamp meter, you can get them for 89-99 USD (more expensive on amazon).. The klein tools are similar and cost a few bucks more. I didn't do any drop tests, but its well built, the only issue I have experienced is the clamp some times needs slight adjusting when closing. As far as accuracy I'd say it's accurate enough for my needs but I don't have a fluke to test it against. You can find some comparisons on youtube. As with professional equipment, you are supposed to have these calibrated once a year for accuracy.How well has it held up over time? Is the case solid? i.e. if you drop it from working height would it break? Is it accurate when checking against another meter?
Seems I am in the market for a new meter and in light of the spendy prize of the Fluke-393. So these are serious questions.
This has been my experince with any of the meters I have gotten from harbor frieght - The freebies/$5 especially but also more expensive ones, I stopped at $30 on one and that was a mistake the first time I dropped it there was no putting it back together again no matter how much bailing wire and duct tape I used.
Here's one I melted a while back when some idiot thought it would be a great idea to measure current of the panels hooked up to a 24V 100Ah bank...
Surprisingly the meter still reads voltage accurately, amps don't work...
I've been very happy with this meter, unfortunately it's not available. https://a.co/d/4EP9P5d
Try to get one that has decently high inrush readings too , as sooner or later you will need that for somthing..Ahh, ok. I will not be doing this again!
Should I replace the circuit breaker?
I will open it up and see if the fuse has blown.
Next purchase will be a clamp on Meter. I have one on the wish list on amazon.
thanks again.
The meter works well ….. I’m amazed your meter is not fried. Watch some videos on youtube or better get someone local to hell you. DC will burn the crap out of you. AC will kill you. Zero shame in asking for help. Everyone had to learn. Electricty needs utmost respect you and I - everyone needs to do our best to learn. I’ve been working with electricity since stuck a fork in outlet about 5 yrs old. It tingled so good.
This one is also on my list.This 2A, 20A, 100A works for me for it's low current range.
This sounds very similar to what I did.Here's one I melted a while back when some idiot thought it would be a great idea to measure current of the panels hooked up to a 24V 100Ah bank...
Parents car keys, outlet, 3 years old...HA HA, I thought I was the only one that did things like that![]()
Can only speak for what I have seen, I bought the Klein CL 900…about $180.00This was suggested as an alternate - it looks promising.NO DC inrush
Has DC inrush - Questionable - in one add it says it does it and in one it doesn'tNope - ac only - the add is wrong
OK, I looked at the specs on at least 50 meters - all the major mfg of quality and the cheap stuff - have come to one inescapable conclusion - only Fluke will stand behind a setting of DC inrush current and put a tolerence on it. Others either don't support it at all OR they claim it but have a disclaimer that the first 300ms is not counted when measuring inrush (WTF to they think people are trying to meassure?) .
I suppose it makes sense if you think about it, they build the circuit for high accuracy and scale for hundreds of amps. Inrush could be 3 to 5 times that or more. They don't build them for that.
The other thing is the frequency of AC the various meters support in AC mode - even the fluke is 5HZ with ±0.1hz - so basically the DC rise time for inrush is hard to measure with anything portable. It seems the DC inrush they are listing as supported is for testing starter caps for motors and is limited to 5amps.
Which means my dreams are dashed and I will just have to settle for a generic meter and it will be much cheaper that way.
If anyone has a DC inrush setting please list the meter vendor and number so I can look it up in case I am wrong.
Inrush ac and dc They behave differently Going from locomotive dc traction motors to ac traction motors and inverters was significant change.This was suggested as an alternate - it looks promising.NO DC inrush
