kentdavidge
This thread advises us to use 14.2V as absorption voltage. Questions:
(1) Is this the voltage I should set on my MPPT charge controller?
(2) That thread also say "the charge rate will be reduced at high SOC. THIS IS NOT A GOOD IDEA IF YOU ARE NOT ABLE TO BALANCE FOR VERY LONG."---so should I actually set a lower value on my MPPT (like 14.2V)?
(3) whatever the voltage set on my MPPT, can I configure my JK BMS to limit the charging current? Because I heard somewhere that LiFePO4 like being charged at 30% of its rated capacity for longevity.
