memilanuk
- Apr 21, 2021
- 125
So... after spending what seemed like too much time removing cable clamps in awkward locations and *gently* slicing the tape holding wire bundles together... I've got a much better idea of what wires were going where, at least in terms of the factory wiring. Some of it makes sense now, and some of it... still doesn't.
I'm in the process of adding lithium and solar to a slide-in truck camper. I've got a whole lotta Victron stuff ready to go in - MultiPlus 12|2000|80, SmartSolar 100|50 MPPT, Orion 12|12|30, Lynx distributor, etc. The plan was to tap the #10 gauge 30 amp line for the 'house' DC distribution panel off one end of the Lynx, rather than use up a slot for such a small load.
Seems like there's a whole lot of wire that could be cut out of the OEM install, and not hurt/change anything significantly:
(the rolled up black & red wires are all the excess from the factory solar pre-wire)
Schematically, this is what it looks like:
(the upper right corner is where it lands in the house distribution panel)
Since I'm going with a DC-DC charger, fed separately by a dedicated #6 AWG line from the truck battery/alternator to a fused spot on the Lynx, I should be good to lose the one 'short stop' auto-reset circuit breaker that ties that in.
And since I have a whole big DC bus bar system with a dedicated Blue Sea battery disconnect and class T fuse, I probably don't need the old plunger style battery disconnect, or the umpteen feet of wire running back and forth between it and the short stop CBs and the DC distribution panel.
The install manual for the distribution panel (Progressive Dynamics PD4000 w/ 4045 converter) shows an option for having a jumper between the 'BATT +' terminal and 'DC DISC' terminal, if you aren't using a battery disconnect. I called PD, and the person I talked to said (they thought) that was to bypass the battery and feed the DC ckts from the converter... but that's not the way it's wired from the camper manufacturer. Right now, the black wire w/ white tape bypasses the battery disconnect, so the battery stays 'hot' from the charger even when the disconnect is off. The house DC loads are off, though.
I'm thinking that when I lift the leads and mothball the OEM charge converter in place, I may just put a jumper back in there, so when the main battery disconnect is off, *everything* is off, as expected. Probably keep one of the auto-reset CBs in line from the bus bar, just in case.
Unless there's something I'm over looking here...
