skykidnv1000
Curious
- Sep 18, 2021
- 14
I was testing my new MPP all in one 1012LV controller to see if the overload function would work.
I assumed that from setting 23 (overload bypass) that if I enabled that, and put the unit into an overload situation it would switch to "utility" mode (provided the unit is plugged in) and carry on.
Instead - I got an error code 7 (overload) blinking on the screen and the unit isolated to just charging the battery from the solar panels. No load to appliances.
I turned the unit off and back on again, and it is supplying power to the appliances but the error code is still flashing
Any Idea's on how to clear that???
