I am close to finishing my solar install (will schedule final inspection this week I am hoping). I still have to learn how to setup/configure the 3 eg4 6000xp's etc though once I get my green sticker. But I am wondering about monitoring the system. I know the 6000xp has some monitoring built in via app/web but does it have a smart shunt, is this something I want to add? If so can I use a victron smart shunt and cerbos gx to monitor the system, or will that only give me battery monitoring and not be able to connect to the 6000xp at all, is this necessary that it connect and communicate with the 6000xp's? I have 2 victron lynx I am using as bus bars for all the batteries so would be easy to add the victron smart shunt and cerbos to it. I currently have 60 kWh of batteries setup/built (and about 70 kWh worth of new cells to build 5 more batteries). I am using 200 amp with 2a active balancer JK BMS's on each battery. What is the best method for monitoring via app/local network/web page etc? Or is what the 6000xp has to offer as far as monitoring is concerned enough and no need to bother with a separate system/smart shunt etc?
