42OhmsPA
What's in a title?
Watch out, I've been thinking....
With multiple packs in parallel is using closed loop really worth it?
How many users are running closed loop with SOC that is not accurate across multiple BMS?
I've ran open loop since day 1.
I attached what my packs looked like this morning, big differences in SOC...
In an open loop setup SOC doesn't matter, voltage rules; open loop is opposite.
So someone using closed loop with 6+ packs in parallel will more than likely have extreme SOC variations due to the poor accuracy of BMS at low current.
For example, under 0.5A or 26W per BMS will not be accurate; with 6 packs in parallel anything under 156W will be inaccurate.
Another issue is cells out of balance. SOC hits 100% or 20% because a single cell hits the trigger while the rest are not full or empty... In closed loop wouldn't charging / discharging stop vs open loop would rely on overall voltage.
I just don't see any benefit to closed loop and often it is recommended to disable it to try and resolve issues...
Make sense or should I get back to work?
