bsr
Hello.
Making progress on my schneider system (details on signature). I setup the BMS through Modbus following the instruction , and it display the battery info correctly. I also assigned it to the correct battery bank. Now, in the xw pro configuration, I selected BMS as the charge cycle and not sure that is enough to have a closed loop with the battery. There is also BMS setup on insight local configuration, and explicitly allow EG4-LifePower4 and LL. I read somewhere the powerpro batteries are based on LL. Can you please let me know if it possible to have a closed loop with EG4 PowerPro WallMount AllWeather battery? Can I select LL as BMS integration? What other steps I have to do?
Thanks
bsr
XW Pro configuration
Thanks
bsr
