D
Deleted member 783
Guest
I was just checking out Renogy's new panel. It's 70% more expensive. All you get for that is 1% more efficiency. Apparently their big selling point is fewer gridlines?! Wow, that's weak Renogy.
Renogy 100 Watt 12 Volt Eclipse Monocrystalline Solar Panel High Efficiency Module Off Grid PV Power for Battery Charging, Boat, Caravan, RV and Any Other Off Grid Applications https://www.amazon.com/dp/B01B3TEM1E/ref=cm_sw_r_cp_apa_i_Elo8DbGXYA361
