Bowlegs868
I'm just curious about the wiring in my combiner box — the wiring goes as follows:
(See attached photo)
One positive (+) from the 2S2P solar panel array goes into the first breaker, the second positive (+) goes to the second breaker, then out of both breakers into the surge suppressor's positive (+), the two negatives (-) from the 2S2P array goes to the surge suppressor's negative (-), the ground from the array frame goes to the battery negative (-) and a positive and negative wire comes out of the surge suppressor to feed the SCC
Is this ok? Can it be improved in any way?
