HI All,
I've looked in the MPP manual and didn't see any "don't do this".
I will have two PV Strings going to a MNPV6 with a split Positive bus bar with separate breakers for each string. The negative is not split so I am thinking they can be run in common (bonded) in the MNPV6.
I will then have the split positives and two "bonded" negative lines running to two MPPT on a single LV5048.
The question is: Can the negatives be "bonded" at the MNPV6 or should they be split also?
Thanks.
Thanks.
