Combining 2 solar panel pairs
jwcole04
Seattle
I have a failed naturesgenerator elite system which I expanded to 2 pods and 4 solar panels. I tried working with ng support to fix the system to no avail. It's a long story I don't need to go into, but suffice it to say their claim of lifetime support is BS.
I have 4 perfectly good panels I mounted on my patio roof and want to use them with a diy system - and have been researching charge controllers and inverters.
The panels are configured in pairs with parallel connections on each pair. To see if they were working I cut the cable and stripped the wires for the first pair and used a multimeter to test them. On a partly cloudy day I got a reading of 18v for one pair - same on the second pair. I twisted the 2 positive wires together from each pair - same negative wires and still got a reading of 18v.
Now my question - why didn't I get a reading of 36v?
Thanks to anyone who can help. I'd like to use all 4 panels if possible.
When connected in series.
Voltage is added together, and amperage remains the same.
When connected in parallel.
Voltage remains the same, and amperage is added together.
To get series voltage rise, you need to connect the pairs positive to negative.
So, two panels will be panel 1 positive to panel 2 negative.
Panel 2 positive to the charge controller. Panel 1 negative to the charge controller.
Thanks Supervstech - I'll try it when we have some light - it's 6:30am now in Seattle.
That's it- thanks man!
Each pair showed 19v .38a
Connected each pair per your instructions showed 39v .22a
Does the lower amps for 4 panels look right? I don't really understand, but don't need to. Also, these are 100w panels.
I'm going to use one of my boat batteries for storage, and possibly add a second. It's a West Marine lead calcium battery, and although it doesn't say so, I'm pretty sure it's a deep cycle. Is there something better I can use?
Thanks again for your help.
Amps will change based on sunlight intensity and load demands.
I am not familiar with that type of battery, so i cant say.
I do like the LiFePO4 batteries, but they cant tolerate cold weather.
Post your plans, and the specs on your equipment if you need help with anything.
Thanks Supervstech!
I have a Victron energy smartsolar mppt 100/30 charge controller hooked to a LiFePO4 battery. The multimeter shows 42v coming from the panels, but I get no readings (solar volts, current, solar watts, etc.) in the phone app except battery volts (13v). The app gives a message that the panel volts must be 5v above the battery volts which they are obviously. Do you have any idea what the problem could be?
Thanks
What are the charge settings on the controller?
It may think 13v is full.
the charge setting is 7 which is Lifepo4. The battery is new and is 100% charged - I checked it with a meter. Is that the problem? Should I run an applicance on the inverter for a while to draw down the battery charge?
If your battery is fully charged the charge controller isn’t going to put any power to the battery. Drain the battery some and then watch what is being generated
