teisen
Hey everyone,
Looking for some advice on a tricky setup. I've got two 200A main panels, each with its own meter from the power company (Georgia Power). One panel is barely used (just a water heater and some lights/outlets), while the other is loaded up. Both panels seem to be connected with only 3 wires to their respective meters.
My electrician says any changes require replacing the wiring to the main panels, which sounds like a major headache. I'm considering adding solar to the mix and using a GridBoss to combine everything down to a single meter.
Here's where I need your help:
Grounding: Can I run a separate ground wire alongside the existing 3-wire setup? Or do I need to replace it with new 4-wire?
GridBoss: Is this a suitable solution for my situation? Will it play nicely with two panels and the planned solar integration?
Are there any other options I should consider besides the GridBoss for managing this setup?
Thanks in advance for your help.
