I have an issue in that my cells came with 6mm welded terminals instead of the requested 8mm. The smallest terminal home on a 4/0 lug that I can find is 3/8” - this is two big for the area at the base of the terminal.
Seeing that my BMS uses multiple smaller gauge cable I figure it should be no problem doing the same from cell to the main battery terminal. If this is true is there a reference available to show what combination of smaller gauge is required to get to the desired ampacity?
