I recommend anyone looking at switching to LiFePo4 in general to read this. Yes, it's long but he has some extremely valuable information from the testing they have done and extensive research. Could save someone $$ down the road. Pay special attention to the sections on the alternator and associated protections, charging etc.
LiFePO4 Batteries On Boats
Here is a quote:
"Stop worrying about not being able to start your motor with a low battery. I purposely started our Westerbeke 44HP diesel at the 0% SoC point of 2.9VPC and did so 12 times in a row. After a dozen starts I simply gave up because I got bored. The battery could have delivered many more starts even at 0% SoC. Enjoy the peace and quiet sail back to the mooring or marina at the end of your cruise."
LiFePo4 can handle an incredible high surge, even almost dead. An installer than I know has done some of the same testing as is mentioned in the article. Starting large diesel trucks on 100AH or smaller cells if I remember correctly. They handled it like no lead battery could dream of.
I wouldn't normally recommend this BUT there are situations where that it MAY not be an issue to pull a tap from the cells directly (bypassing the
BMS) and go to the starter ONLY. It would still be prudent to use a contactor between the cells and the starter. You'll want to wire it so that if the BMS sheds, the contactor opens.
Also remember you don't need a contactor rated at 1000A continuous. You are only starting, not continuously cranking the engine. Most high-end contactors will have a surge capacity over time chart. I believe some of the Kilovac 400A or 500A have a surge of 3000A or more for a few moments.
