chrisblessing
- Sep 20, 2019
- 123
Greetings. I have a small camper on which I have and Eco-Worthy 160w flexible panel. The specifications are:
Needless to say, after 3 years output has degraded, so that I generally see a maximum of 45 watts and about 2.9 amps in full, overhead sun. With good exposure the panel is sufficient, but without much margin for clouds or shade. What I wonder is whether adding a 50w flexible panel for which the camper has room, might be a just-ok way to supplement the older panel. The new panel specifications are:
I understand the downsides of combining different capacity panels in series, but given the degraded performance of the original panel I estimate that combining the existing and the new panel I should have a combined output of roughly 90-100 watts and current of about 2.7 amps. My perspective is that the original 160w panel now offers about the same capacity as the new 50w panel. Does this sound anywhere near a reasonable perception?
A few things to note. First, the camper is small so I only have enough roof space to accommodate the original panel plus the additional, much smaller new panel. Secondly I can purchase the new panel for a low enough price to keep my overall investment within reason until such a time as I can upgrade the entire system. Finally, my battery is a 120Ah LiFePo4 DIY with a Rich Solar MPPT charge controller and Daly smart BMS.
I appreciate any input but ask that any responses acknowledge that I prefer not to spend more than the $80-100 I have budgeted for this this.
Thanks so much. This forum has been invaluable for me
160W | |
Max. power Current(Imp) | 9.06A |
Short circuit current(Isc) | 9.60A |
Max. power voltage (Vmp) | 17.7V |
Open circuit voltage(Voc) | 20.68V |
50W | |
Max. power Current(Imp) | 2.71A |
Short circuit current(Isc) | 2.92A |
Max. power voltage (Vmp) | 18.5V |
Open circuit voltage(Voc) | 22.6V |
