chrisblessing
- Sep 20, 2019
- 123
Greetings. I have completed the installation of a 160 watt flexible panel on the roof of my Scamp camper, connected to an MPPT charge controller and 120Ah LiFePo4 battery bank. Given the drawbacks of using a fixed panel in inclement weather or shaded spots, I'm wondering about the possibility of also connecting a 120 watt folding panel to my battery bank. This panel has it's own PWM controller and is rated at about 12v output, as opposed to the 18v of the fixed panel.
As far as I can determine, the most simple way to use the folding panel is to simply connect it directly to the battery bank in conjunction with the fixed panel and charger. Before attempting this, I'd appreciate some input from others.
Thank you.
Thank you.
