Actually, I'm going to split hairs a little bit here. Nearly every one of these are not acronyms, they are abbreviations. An acronym is an abbreviation that can be spoken as a word. Examples of abbreviations that are acronyms are: NASA, SCUBA, FUBAR.
I'm new here and have just been sucking up information and until now, this is the only thing I can contribute.
Actually... your Webster definition states it is a word... words are spoken.I prefer the Merriam-Webster definition, which doesn't require the acronym to be spoken as a word.
Acronym - a word (such as NATO, radar, or laser) formed from the initial letter or letters of each of the successive parts or major parts of a compound term
Thanks!...Should be:
- CYA - Covering Your Anatomy, actions taken so a person doesn't take the blame for something.
Thanks! Title fixed!...Nearly every one of these are not acronyms, they are abbreviations...
Who is taking the blame on that one?This one needs some help:
Should be:
- CYA - Covering Your Anatomy, actions taken so a person doesn't the take blame for something.
Blame take I |
I'm late to this party but just a comment.V - Volts, a measure of electrical force.
FET is covered with (MOS)FET, but C isn't there.How about FET, and C ?
Removed terms unrelated to solar PV would be a good start. e.g. stuff like YMMV.Sadly, the OP is at the maximum post length, so something has to come out for something else to go in.
Is there a way to split it into two posts? A-L and M-Z?Sadly, the OP is at the maximum post length, so something has to come out for something else to go in.
Done, acronyms added/edited/corrected/futzed-with. Thank you in advance MrNatural22!Is there a way to split it into two posts?
C | Coulomb |
C-Rate | (Dis)Charges per hour |
C was entered the other day, courtesy of Johannlog. C-Rate isn't in, so I'll add it...but just an FYI your definition is off a bit.
C Coulomb C-Rate (Dis)Charges per hour
Really? isn't Business to Business a more common use for that acronym?
- B2B - Battery to Battery
Nature produces more daily.The Oak Ridge National Laboratory (in the US) produced the highest ever at 25.5MV (Million Volts).
What a DIYer would be doing with that
