Mark48vMagnum
I’m having a communications issue with Lifepower4 EG4 BMS to my laptop.
I have 6 Lifepower4 48v/100Ah battery modules set up in 2 battery racks. Batteries were put in climate controlled crawl space with 48 inch height, this was why I used 2 battery racks instead of just 1.
I have a 6 foot Cat 5E (RJ-45 ends) cable run from garage RJ-45 wall plate down to battery module #1 RS-485, this cable is 6 foot long. I have standard jumper cables on all battery modules except for battery modules 3 to module 4. (Rack #1 to Rack#2) See Picture
The jumper cable from battery 3 to battery 4 is a CAT 5E cable and is 3 foot long.
All RJ-45’s and wall plate receptacle are wired Standard (T568B Pin-Out)
Pin 7- White/Brown Strip (D+), Pin 8- Brown (D-)
I’m using the dongle supplied by Signature Solar from garage wall plate to laptop.
DIP Switch on battery Modules all set to proper addressing from manual, and rechecked, and rechecked.
The software I’m using is BMS-TEST-Lifepower4.
When I open the software it opens at “Configinfo Screen.
App Baud Rate: 9,600
Boot Baud Rate: 115200
Port is: COM 2 (USB-Serial CH340)
I then go to Batinfo Screen and set Packs Number to 1.
Then I enter start Address of 0 (for #1 Battery Module)
Long story short software will communicate with Battery Module #1 (Adr.0) and Battery Module #4 (Adr.4)
I can’t get software to bring up Battery Modules #2, #3, #5, or #6.
I have tried to do modules separately (Stand Alone) with just dongle cable between laptop and module and using address 0 (All Dip Switched Down/ON) but will not bring up Modules #2, #3, #5, or #6.
Makes no sense…
Any Ideas on what could possibly be wrong???
Thanks
Makes no sense…
Thanks
