Technically, yes. However, it's always recommended to construct a bank of parallel batteries with the same capacity.
Important to connect them using best practices. Heavy interconnects between the batteries and you use the main (+) on one battery and the main (-) on the other for your charge/load connections.
So it will work? going to an area that has frequent rain. Worried about not having enough sun to charge my house battery.
would it be better to have a dc to dc charger. Wonder if the stock alternator would be enough to do this.
going to an area that has frequent rain. Worried about not having enough sun to charge my house battery. would it be better to have a dc to dc charger.
This is the video that peeked my interest about adding different ah batteries in parallel.
As long as voltage are the same will work?
Even if you have multiple bms's??
I'm in same boat. Have 206ah SOK and wondering if I could add some 100ah in parallel!
