Firstly, I’ve spent the last several months reading through this site and learning more than I ever thought I would. So thank you to everyone who has put countless hours into sharing their knowledge. I'm really excited to get going on this project, including DIY Lithium battery (the only component I have already ordered). We have a 1976 Islander 36 with mostly original parts. We’ve had it for 5 years and have completed several upgrades (in the wrong order - lol), but it’s time to overhaul the electrical system.
A little context for the usage. The boat lives in British Columbia, Canada and so while I like to think we sail a lot, there is also a lot of motoring as we navigate the long narrow channels and inlets. Right now the trips are up to a week or so - anchorages are at most 2 nights without moving, so there’s plenty of engine time for recharging.
Medium to long term we plan some longer trips – Van Isle Circumnavigation, heading north to Haida Gwaii, and maybe even a Hawaii trip. This means short term no solar installation, but before these longer trips we would add solar into the mix. So this system is designed to accept solar in the future.
I’ve put together a preliminary diagram (attached). I will continue to refine it further down to every wire (and gauge), fuse, etc – but for now am looking for input on the decisions I’ve made, and any advice on if I’ve missed something or not considered something. I do have a couple of specific questions mixed in below:
House Battery
- My conservative energy calculations for a full day coastal sailing (with autopilot) plus overnight anchor put us at about 100 amps
- I’ve chosen 304Ah EVE cells for the house battery based on recommendations on this forum for suppliers (Jenny – Docan).
- I will use 4 cells for a 12v system to match the existing 12v on the boat.
BMS
- I’m decided on which manufacturer at this point and open to suggestions
- I like the idea of one that would communicate with other devices on the boat (So possibly Wakespeed with a majority of Victron components)
Alternator
- The boat has the original Perkins 4.108 with an original Delco alternator (40 amps I think). While the engine is in decent shape, I’m reluctant to put the labour and additional cost into a belt upgrade to take advantage of increased amps as there may be a re-power in the future
- Therefore I’ve decided on a 100 amp 6 series – The expectation being that we would run the engine generally for 2 hours a day minimum (departing anchor and arriving anchor). If we get only 50 amps each hour, we would replenish our daily usage. I can’t see a day with less than 2 hours coastal cruising.
- A Balmar 618 Regulator will keep the Alternator safe, but not looking for any of the data connections at the moment.
Overload Protection.
- The sterling device is cheap, and allows for direct charging of the battery.
- I don’t like the idea of DC to DC for charging the house battery. Seems to be counter intuitive
- I’m not fully understanding if the battery disconnects and the Sterling kicks in, what are the next steps? Can the BMS communicate with the Regulator?
Starting Battery
- I will stick with a FLA 12v starting battery. There’s no savings here – the existing start and house battery are end of life, so open to suggestions here but I don’t see a reason to go anything else here.
- Charged via DC to DC charger on a separate circuit
- I’ve currently designed the system to be separate, but am open to designs that could allow the house to be the start if necessary (short of the current plan for emergency wiring as needed).
Victron ‘Smart’ Monitoring / Operation
- The whole ‘connected’ line of Victron looks to a mess of products and poor documentation. The fact that Victron has built their online manual site to a wiki that anyone can edit is suspect.
- With the minimal documentation on the Octo, I’m not sure it’s the right product, but I used the page here to compare my needs (https://www.victronenergy.com/live/venus-os:start)
- Perhaps the Cerbo is the ‘latest’ model? It certainly looks more future proof with dual processor and double the RAM of an Octo. It appears to be less than $100 more
Bus Bars
- I have designed this with 4 post bus bars on each side of the battery. On my diagram I have indicated multiple connections on a single post by putting them close together. I believe a 100Amp bus bar should suffice for the loads. If the alternator was upgraded in the future I could go direct to the battery and bypass the bar?
- The AC& DC Panels, MultiPlus, and Octo are all on the port side of the boat, with the rest of the equipment generally on centre close to the engine and battery.
- The distance from the battery to bus bars should be relatively short (a couple feet or less)
- Is this ok, is it going to give me problems?
Thanks for taking time and providing input.
House Battery
BMS
Alternator
Starting Battery
Bus Bars
