@Daddy Tanuki - Thank you for the many points! Having said that, there is a lot of information in the last 21-pages and I hope the forum recognizes how open I've been to taking feedback and adjusting my plans.
As noted, I have a few critical constraints:
- Space - The supermajority of my property is classified as a preserve, leaving me a small parcel to 1) Build a House and 2) Build everything else I need (Pole Barn, Solar, etc.).
- Diesel - Literally makes me ill to smell. No bueno and not a viable solution.
With that said, I've acknowledged the following:
- Generator - Must have and will be powered using propane
- Load Calculations - Necessary and I will calculate them (FYI - I'm an Engineer by background, I understand these calcs but just needed someone who has experience doing these projects to point out what I need to worry about vs. not).
- Demand & Usage - I have conceded numerous times that the numbers I've calculated are highly skewed based on the HVAC system which is sized currently at 5-Tons per the HVAC company; however, these numbers are a pure guestimate considering that my floor plan is not yet complete and they haven't been able to do a formal analysis to determine how much I really need.
==> Therefore, we will adjust as required once the floor plan gets ironed out and the HVAC analysis is performed.
Until then, I work with the calculations I have - get a great education from the gurus on here - and come up with a plan which would then be modified once the final numbers are in-hand.
The flow currently is: Panel Design (vs. real-estate) ==> Battery Design (vs. where it will be located) ==> Inverters (location) ==> Connections (sizing, quantities, etc.)
I really appreciate everyone's help!
