Al Slitter
Trying to learn something new every day!
I am considering upgrading my solar system from a lead acid battery system using 2-55 Amp panels connected in parallel with a cheap but good working PWM controller.
This system was set up about 2-years ago as a testing environment in my small workshop. At present the system has a 12 volt DC light source (Night Light) which is connected to the output ports on the PWM controller.
Is is still working good, yes is the answer!
However with lithium cells pricing dropping and the battery in use aging it is now time to think about a redesign and upgrade to the system.
I want to keep my panels as I do no have extra room for additional units. My shop is facing the wrong way.
Can someone please provide me with the main advantage of going to 24 Volts from 12 Volts.
I am fully aware of the cost of cabling and the cost factor of a BMS needed, but what else?
With the cost of the batteries and my limited utilization I would most likely stay in the 100 to 200 Ah cell range. Why 200 well because of the fairly low cost difference.
There is in my mind an idea of adding to the system a small inverter and using that to test out possible future plans?
Thought please anyone.
