Compress or not, flexible busbar or not
I have watched all Andy's videos, but I wasn't convinced no compression was the correct way to go, so I compressed with foam and used flexible busbars.
Same.
I compressed with plastic sheets and made up flexible busbars from lugs and cable.
Compression will not stop bloating. Only causes bulge on sides and/or increased cell pressure. Popping the vent port is worst result.
Root cause is electrolyte break down. Overvoltage, high cell current, or high temp is most common cause of electrolyte breakdown. Less than 0.1v cell voltage will also cause bloating but that is not so common.
In Andy's case I would suspect high temp or high discharge current. The different age and condition of three banks can result in over current discharge on one of the strings. Needs to pay more attention to total current distribution between the three strings. Getting above 0.5 C(A) on a given string is a red flag.
Root cause is electrolyte break down. Overvoltage, high cell current, or high temp is cause of electrolyte breakdown.
I hope Andy gets it sorted out for himself
Back on page 1 of this thread, Andy from the Off Grid Garage YouTube channel was referenced as saying why he would not compress. I wonder if Andy is having 2nd thoughts?
I'm not saying, compression right or wrong. I don't know anything.
It was just interesting that a video at the top of this thread was referenced, and the same video creator came back a year + later with findings
Compression is good if you subject cell to high current. The object of compression is to minimized delamination of electrode material from their graphite negative electrode copper current colllector foil or LFP electrode to aluminum current collector foil.
Below 0.5 C(A) cell current, compression yields little benefit.
When electrolyte decomposes it causes dried out hydrocarbon tar gummy areas that increases stress on separator sticking to electrode causing pulling on electrode causing delamination. In the picture if there is fluid electrolyte permeating porous separator there would be no reason for graphite to stick to separator. This cell has been subjected to overcharging, overcurrent, or over temperature that resulted in electrolyte decomposing to dry, sticky, hydrocarbon tars that stuck graphite electrode to separator.
The electrolyte decompostion gas, mostly CO2 and CO, produces gas that bloat the metal container. It is not the most damaging affect, it is the other hydrocarbon tars created and left behind in the laminate.
I think Andy’s cells will be fine as long as he gives them space to get the tension off of the terminals like he did on the top shelf. From what I’ve read, compression of swollen cells is a bad idea. His cells are mildly swollen and probably not an issue. I have and still will continue to compress with a centralized spring of a known spring rate. Time will be the true tell.
I agree, the bloating is not that bad.
This.. i compressed because mistakes happen. Bms malfunctions and because manufacturers said the cells will have more cycles so why not, it’s easy to compress them.
This is kinda conflicting but I get what you mean. However since compression can minimize delamination, doesn’t compression do that by stopping expansion? bloating and expansion being different
My objection to compression is many DIY'er do a non compliant fixed dimensional compression that results in an exponential increase in pressure at full charge or higher ambient temperatures.
You can crack electrodes or crush separator causing a cell short if too much compression is applied. The spec list 300 kgf across cell surface which is 29 lbs per square inch which is high risk if not carefully controlled. The separator, preventing a cell short, is only a very thin, porous polypropylene plastic sheet.
If you want cell longevity don't run them above 0.5 C(A). Above 0.5 C(A) the cell internal temp cycling increases due to internal cell heating that stresses electrode lamination. At 0.5 C(A) maximum current there is low internal cell heating and cell compression has little benefit.
You have to weigh the risk versus benefit.
Do you differentiate between true cell compression and what would be more of a fixture frame that presses the cells together for mobile and RV applications. Or would those b essentially 1 in the same from a design, concept and execution point of view.
You need some sponge or spring compliance to keep pressure uniform over some dimensional expansion and contraction.
A few threaded metal rods to end plates is a hard fixed dimensional compression that can exponentially increase compression pressure when cells expand.
The surface of cells is not uniformly flat so a hard flat surface can create high pressure points. A compliant rubber pad between cells helps to even irregularities in cell surface.
Exactly why I decided to use springs
This was my only concern with they way I did it. I have 2 rows of 8 cells , with 1mm PCB sheets between each cell. At either end of a row is 1/4 Poron foam, which is compressed using 10mm aluminium plates and studs/bolted tubes. I would have preferred foam between each cell but just couldn't buy the correct foam.
My second battery should be online at the end of the month, even with one battery I don't go near 0.5c even though I could. The most I've seen flowing in is around 100A with 280ah cells. Once the second battery is in, I'll charge at 140A, so 0.25C for each battery, solar charging will be less.
My biggest concern was when one cell was nearly flat and the next had a slight bulge(less than 1/16) and could violate the flat plane of the other. All the batteries I’ve seen have two vertical bulges where the “jelly rolls” reside so there will be two pressure points regardless. I fitted Formica sheets between each cell to help mitigate protrusion from another and provide insulation. I tried to find the fiberglass sheets like you see in the kits and they were too expensive. The ends are doubled up glued 3/4 ply. Even with 500lbs each row of eight have moved the pusher plate 3/16 and move very little through the cycle now. Basically, they have moved what they’re going to after 16 months.
I’d love to see what the close fitting rack cells look like after a year with welded busses and nowhere near an expansion force strength structure. Do really want to even look? It may give you an idea what the cells can actually take as far distortion and stress.
@MrM1 Its not so much the density, its the ability of foam to push back, just like a spring.
Think of it as a spring, squash the spring, two months later when you release it, it will return to the same length, so its still exerting pressure.
If you squash most foams they will take a set, release it after two months and it stays squashed, so it stops exerting a pressure.
You also need to know how much pressure the foam exerts, and unless you can get a data sheet for the foam, you won't know.
Silicone is Approximately.045” thick. Went this way at first but changed my mind to Formica. 8AAE8386-A9E3-4F64-9667-560273E01ED6.png
The red colored, high temp silicon rubber pads is probably the best to use but it is rather expensive. It has a good durometer (optimum sponginess), is resistant to taking a compression set, and its high temp capability may help reduce likelihood of any adjacent cell thermal transfer cascade runaway.
Neoprene rubber takes a compression set over time, has a rather low melting point, and is a thermal insulator.
You don't want to use a material that takes a compression setting collapse under long term compression.
The idea pad thickness is when about 25 lbs/sq. inch of pressure compresses the pad 20-40% of its uncompressed thickness. This amount of compression stays in linear compressive force range. With the variability in cell surface flatness this will likely take a minimum pad thickness in the 1/4" to 3/8" range. The thicker the better, to hold uniform pressure across surface of cell and avoid pad taking an over-compression set.
The downside of all of this is you are reducing the cells' ability to dissipate any internal generated heat by wrapping two large sides of cell with a thermal insulating blanket. This partially defeats the original intent to reduce delamination of electrodes from metal foil due to high temp excursions.
Here we go again!
I tested the 0.25" Poron foam and found that one sheet per four cells is what you want to use for cells that specify ~12 PSI compression and up to ~0.5mm expansion per cell. I used one sheet in my four cell battery and two sheets in my eight cell packs.
I am confident that whatever slight imperfections the cell sides had when I started (it wasn't much at all) conformed as needed to meet the rigid separator and the next cell over.
Link to the actual test results:
https://diysolarforum.com/threads/a...this-time-about-foam.16537/page-4#post-530262
By the way, the EVE specification sheets seem to no longer talk about allowing expansion; they state an initial compression force of 300kgf at ~30% SOC and clearly show a rigid fixture. It seems that they no longer are concerned about "over compression."
Ofcourse they aren’t concerned about over compression or allowing for any expansion. They state X amount of cycles for a fixed compression and as long as the cells reach those cycles they are in the clear.
Allowing for expansion is a must imo. Mistakes happen. Overcharging, over discharging etc. allowing room for mistakes is good insurance. Also as we discussed before there is the possible extra pressure towards the end of cells life. allowing for this extra expansion/pressure could be a good idea.
