Woodpecker66
Hello All.
I have 3 of the Yixiang DIY 280AH battery boxes which are designed to be stacked on top of each other. The cells in the box
would be oriented with the terminals facing up. The general consensus on compression is around 12psi, so if the sides of the cells are
80 sq. in. then that equates to 960 pounds, is that correct? The reason I ask is I would like to stand these boxes on end rather than stack them on top of each other.
Based on cell weight, that would mean the bottom cell would have around 85 pounds sitting on top of it. Are horizontal compression force and static vertical weight load comparing apples & oranges? I know of one person who has done this with no issue for 6 months, but I want to be sure there is no chance of any long term negative effect on the lower cells having that much static weight sitting on top of them. I appreciate any input. Thanks
