Instead of using material like that, you should just leave the cells loose with no compression. Just because it is cheap and one might think it is beneficial doesn't mean it is.Check the spec sheet
I'm just showing the possible cheap solutions. I don't know if there is any product made specifically for this application, so I just look around for things that would work.
How do the cells expand and contract as SOC changes?Lay cells on their sides and use body filler(Bondo) and screed off flat and level, like concrete, to fill the valley. I believe somebody elsewhere else mentioned epoxy. Probably the same idea. Then use additional whatever if deemed necessary.
Options for electrically insulated dividers, all readily available at your local store and cheap.
I think NMNeil was looking at something to provide extra electrical insulation between the cells. In my opinion, installing insulators between the cells and flexible interconnects to prevent terminal stress are a good idea if nothing more than for peace of mind and extra assurance.If you're not willing to put forth the effort to research and understand exactly what they have, I can't help you. Ignorance can be bliss, I have presented what my research indicated was the best solution for cell compression without spending a huge amount of money. Doesn't make sense to spend around $500 USD for 4 cells, wait over a month to get them but want to be a tight ass when it comes to materials for cell compression. You aren't taking the subject seriously and would be better off leaving cells loose.
What are the strategies against mobile (off road) vibrations to go with the compression? Possibly a denser foam underneath the cells?
That is my question. Under cells, under box or neither as it will make it worse. I would think the compression under impact would need to be quite small
Threaded rod compression is popular. If the valley isn't filled level, it seems if the only area compression would have any influence on is near the ends/high spots. Expansion and contraction would continue unabated in the valley.How do the cells expand and contract as SOC changes?
You would have to determine the compression to achieve 13 psi. That could be tricky as it is 1 mm thick.I have a ton of Floormuffler, foam underlayment (they sent me double for a job). It is 1 mm closed cell, polypropylene foam. Compressive Strength @ 25% is ≥ 40 psi. It says it can be used with radiant heat flooring, and its flammability is Class A per ASTM E 84. Does it seem like this would be good between the cells? Figured with all of the experts in here, someone might know.
No give on the body filler or epoxy. It would work well probably with a spring setup.Threaded rod compression is popular. If the valley isn't filled level, it seems if the only area compression would have any influence on is near the ends/high spots. Expansion and contraction would continue unabated in the valley.
I would venture to guess a rigid material like Bondo or epoxy would do more harm then good as I would bet the cell does not expand and contract uniformly across the entire surface. Every video I have see where someone puts a straight edge on the side of the battery clearly shows where the pos & neg terminal goes top to bottom. That would mean some spots might be at 13 psi but others will be higher or lower.Lay cells on their sides and use body filler(Bondo) and screed off flat and level, like concrete, to fill the valley. I believe somebody elsewhere else mentioned epoxy. Probably the same idea. Then use additional whatever if deemed necessary.
How about these between cells? Silicone Baking Mat
Where did you get it from?I use this stuff. It compresses very little but the nice thing is it's a fire barrier to 1300C and adds 0.8mm when compressed (I use the 1mm uncompressed version).
I'm just reading this and other threads as I am about to assemble my battery pack this weekend.I thought about vhb, but would like to be able to pull them apart if needed so that steered me away from the tape/adhesive route.
