I see a wrench in the worksEffing love those top crossbars!!!!!
One of the hardest things to do is weld thin stainless and not make it look like a sick bird walked by. Nice.I don't have to paint it and it looks so cool. No corrosion, stronger per pound.
Aluminum can be easier to work with than steel. My first cell fixture was for my truck camper, 1/2" thick aluminum and I tapped threads in it to hold the BMS.
I work with just about any material and for some things aluminum makes the most sense. It costs more but the labor involved with painting it and the paint costs money too. I want to assemble it and not have to repaint it down the road. I can weld aluminum, stainless, steel and braze/silver braze. Stainless is hard to work with but for some applications like my shower stall pan in my truck camper it is totally functional and looks great.
Yes, I fabricated the 2 piece shower pan and even coined the drain hole in the shop press. I purchased the power brush for the brushed look and passivated after welding using electrical current and phosphoric acid.
Back to your original question, it is a matter of choice but I liked using aluminum and the 8" wide flat bar is perfect for battery cells. Steel will work.
I wonder if they will appear not bloated because the bloat will go into the foam, if they actually bloat.Done for now. Gaff tape in the middle and 7 layers of clear scotch tape on top and bottom. Need to get a roll of fiber reinforced packing tape. Used a caliper to match amount of compression on all sides. Cells were already little swollen so I did not compress much. This is more like fixing in place rather than compression to spec.
That's the idea. Let them have room to bloat to prevent excessive pressures on the cell while maintaining constant pressure to slow down whatever destructive mechanical effects bloating causes that lead to reduced cycle life in the long run. I don't recall exactly why pressure on cell surface extends cycle life but that's the message from manufacturers and researchers.I wonder if they will appear not bloated because the bloat will go into the foam, if they actually bloat.
Since I blathered on about stiffness, steel is nearly 3X stiffer than Aluminum.
Hi, Good idea on using the strap, How did you tension the strap and what locking clips did you use?Did it this way on a small 24v pack I put together using strapping material and fr4 board
The clips came with the strapping material. It also came with a tension tool as a kit. Could not use the tool because I was concerned on damaging the side of the cells. Instead I put vise grips on the ends of the strapping and pulled it tight. That took some strength but worked nicely.Hi, Good idea on using the strap, How did you tension the strap and what locking clips did you use?
Very nice build!I guess this thread comes back and i never updated with what I did.
Behold.
Maybe this is just the plywood
Yeah steel plate could have kept them in orderMaybe this is just the plywood
