NoMoreGreen
When we set up campsites using the 220 watt Ecoflow bifacial solar panel, we often have to place the panels 10-15 feet away from the camp site. We store the glacier and river 2 pro inside the tent.
We also use a renogy e.flex 220 watt panels.
The xt60i connector is 12 gauge wire and a bit over 8 feet long.
When I build PV cables I use the same wire every time. 10 gauge pv wire rated for 600v.
So with the panel pushing 18 volts, 220 watts, + another 220 watt from the renogy panel if I run them in series. So call it 440 watts and 18 volts connected in series this puts me roughly at 24.5 amps.
15 feet run at 25 amps puts me at 10 gauge wire. My concern is I can’t control the Ecoflow xt60i connected being 12 gauge wire. How do I correctly address this wire and amperage? Do I need to learn xt60i connectors and build my own cables now to plug into the ecoflow devices?
