manfromidaho
I'm brand new to this forum so bear with me. I have a small off-grid system with following:
System: 5000 watt inverter/charge controller (41.7 max current output), (8) 410 watt solar panels, (1) 48v 100ah LiFePO4 battery. I'm looking to add a second battery in parallel with the present battery, giving me a 48v, 200ah setup. I currently use a 30 amp master circuit breaker on the AC subpanel for loads. My one battery is connected using 2awg battery cables through a DC disconnect to the inverter. I use this system to power a garage minisplit, freezer, water softener and recirc pump and a second minisplit inside the house.
My question: with adding another battery in parallel, do I need to be looking at upgrading my battery cabling? I'm currently using 2 awg copper which is rated to 95 amps (4560 watts at 48v). Maximum 120v AC load with my 30 amp AC breaker is 3600 watts. I'm not making any changes on the load side. I therefore see no need to change the cabling from the present 2awg which is more than adequate for my 30 amp 120v subpanel. I will be adding bus bars to connect the 2 batteries with the DC disconnect, but planning to make those connections using 2 awg cables. (Note: Vendor recommended 4 awg in their documentation but I upgraded the cabling to 2 awg.) If I were to max out the inverter and change my 120v AC breaker to 40 amp, I would need to be able to handle 100 amps DC, and at that point I believe I'd need to upgrade my cabling to 1awg based on the standard ampacity charts.
