I am configuring the right panels for my inverter
Can you please help in finding the right panels for my inverter?
Inverter is Voltronic Infinisolar V IV with followig specs:
Maximum PV input power: 6000w
Maximum PV DC voltage: 450VDC
MPP voltage range: 120VDC – 430 VDC
Current panel I found in the market
Longi 545 Hi-MO5
Pmax STC:545w
Pmax NOCT: 407w
Voc STC : 49.65V
Voc NOCT: 46.55V
If I configure 9 in series I will get
446.85V which is good, close and less than 450v of the inverter’s max PV
4905w, which is way lesser than 6000w of the inverter’s max PV input power
If I configure 10 panels, 5 in series, 2 sets in parallel, I will get 5450w, not high enough but lower volts. 12 panels is overkill on watts.
Shall I look at other panels or any other suggestions with the above Longi panel?
Thank you
Longi 545 Hi-MO5
Pmax STC:545w
Pmax NOCT: 407w
Voc STC : 49.65V
Voc NOCT: 46.55V
Thank you
