SheilaInTimmins-ON-CAN
I am confused about getting a BMS for the above battery. I don't see any 230ah BMSs. I cant even find 200 ones for sale. MUST I get one, given I have an all in one (POWMr 5k LVM 48volt mppt hybrid 120 volt only) -will this not allow me to set cut-offs. I do have 2 8S cell monitors I can attach to monitor individual cells. I desperately need electricity - been offgrid for 2 months with only a generator and broken down 12 volt lead acid system.
ALSO the screws on the all in one where I am supposed to attache the battery leads are minuscule! I have M12 size lugs and 2-ought cable -is there some way to make the inverter screws bigger (like one would make a plumbing pipe go from quarter inch to half inch with an adaptor piece. Sorry typos donèt know how to use this laptop. Any help would be greatly appreciated.
ALSO I have taken apart my old mobility scooters and scavenged and found small inline fuse- and some 50amp button circuit breakers-greater than my 8amp solar input-that I could use on solar string series 9x230 watts -and bought an amp wiring kit with 120 amp atc fuse - can I put this between the inverter and battery for now and I will buy a T1 shortly
I also found an old 60 am 220 volt DC breaker box siemans se222 - can I or should I use this somewhere for additional safety. there is already a fuse box in the cabin I just bought in way north ontario near timmins - so presumably the loads are protected from this already installed fuse box...I've read the book and watched 1000 videos but started from knowing nothing at all about anything technical and cant seem to find the answers to my questions...
