WorldwideDave
I want to add solar to my home. I don't want to backfeed to the utility. Battery would be added. Truly not relying on the grid is the option, though I'll have to keep it connected to the house and pay the 30/month or whatever it is. Would be nice to use grid to charge battery on bad sun day/dead batteries/maintenance mode.
I have an old load center at the back of a house near a pool where the grid connection is located. 100 years old house, 100 amp panel is plastered into side, probably done in the 1960s (Cutler Hammer brand), and very few (5?) circuits still go there. No lockouts, no 'main' breaker at the top, and not a 'solar ready' panel.
Inside the panel, there is a 100A 240V DPDT breaker to disconnect the meter in the middle of the panel they call the 'main disconnect'.
At the bottom of this same panel is another 100A 240V DPDT breaker that is a disconnect for a subpanel about 70 feet away in the garage area, added in 1970 we believe. The panel in the garage downstairs has some good newer wires run to it. No aluminum wires left in the house. This is the panel I put the Emporia Vue 3 into, and it's a packed panel wow.
Anyway, trying to decide between two system designs.
In one design, I put the all-in-one next to the main original load center upstairs. I really don't want to touch any of those nylon string wrapped wires likely still in there if I can avoid it. Didn't want to swap the panel back there, as that may be a huge can of worms. That 'section' of the house has a lot of older wires in it. Don't love it.
In the other design, I put the all-in-one into the garage downstairs near the newer panel. However, that panel is overloaded in my opinion right now, as it is a smaller murray panel with 16 breakers in it, and probably 4 of the tandem/double breakers. It's a mess, and I don't love it.
Once design is picked, I'll figure out the replacement of a panel, if needed, and start with that.
I appreciate you reading. Open to suggestions on design.
Attached drawings are not to scale or professional in any way. Inverter/SCC/MPPT would be one icon.
Note: Trying to do this WITHOUT permit. Figuring out where to mount the panels I have is what I'm focused on this week.
