I have a 2001 Great West Van RV. It has an old Magnetek 6332 converter for use with shore power. It has no battery charging logic and just passes the converter voltage to the house battery. There is also a battery isolator between the starter battery and the house battery that allows charging the house battery from the alternator when the van is running. 80 Watts of portable solar panels with portable charge controller.
I plan to install a large Lifepo4 battery to power a fridge with a DC compressor and am considering the following:
A DC to DC charger (that has a Lithium charging profile) with both the Magnetek 6332 DC output and the Alternator DC output to the DC input side of the charger and the DC charger output connected to the existing DC distribution panel and house battery. Does this seem appropriate?
The wiring from the house battery compartment to the DC distribution panel is about a 6 foot run but is only 8ga so I'm thinking 40 amps maximum but will likely opt for 30 amps to be safe. Thoughts?
I'm trying to maximize space use in an already cramped van and I can fit a large Lifepo4 battery in the existing house battery compartment and a dc to dc charge beside the power center.
