Connect Wind Turbine Charge Controller to My Already Solar Panel System
Getaway
Can anyone please advise can I connect a wind turbine with it's own Charge Controller to my already solar panel system that is connected to a ( Renogy Rover 40 Amp 12V/24V DC Input MPPT Solar Charge Controller) my intention is to connect the two chargers to the same battery bank.
Rednecktek
Photon Sorcerer
On a boat usually.
Yes, that's usually how it's done. The wind controller will have DC outputs for the battery and you would connect those to the battery bank just like you would if you were to add another solar controller.
Getaway
Hi thanks for your reply I have connected a smart battery charger in cloudy weather, just to keep the batteries topped up I was not sure if a wind turbine charge controller would work in the same way very Much appreciated.
