Connecting a seplos BMS to dyness batteries in parrallel.
ddonq1412
Looking to add a seplos battery to my existing dyness battery modules. Are they compatible with each other. Or would be in a case I'll loose communication from one of them.
Don't know your specific equipment, but if lifepo4 batteries, then run one in communication mode, and the other will be happy following along. That's what I have. 30kwh in communication mode, and 15kwh with a jk bms that charges and discharges with the other batteries.
If you mean compatible for comms ?
Then they are not
Doesn't mean you can parallel them though, just won't have comms between seplos, dryness and inverter
You think connect the seplos BMS to inverter and daisy chain the dyness batteries to seplos battery.
If your dyness are 16s , the answer would be yes, but make sure first..
If they are not, you would have to choose which ones you use
