I've 2 5kw inverters and 2 batteries ( 48v 200ah each )
The inverter manuafacturer says the inverters can run in parallel mode with either one battery each or a single battery ( linking the batteries in parallel )
My preference is to run the batteries in parallel to ensure each battery is used equally.
Each battery has a 100amp BMS, leads rated for over 100 amps with m8 lugs, can I just join the lug nuts together with a bolt & nut, or do I need to goto the trouble of using a 200amp busbar.
